MARS operation with Power Genius XL
4O3A Signature
Good news for MARS users
Power Genius is designed for high performance on HAM radio bands. Spurious emissions are much better than needed by standard FCC 97.307. Thanks to diplexer filters in output circuit Power Genius can operate in a much wider frequency range without any modifications. Except one very narrow frequency **** from 2,2 to 2,5 MHz, where spurious are > 35dB , Power Genius can operate broadband without any modifications.
Requirements for operating on MARS frequencies:
- Load firmware with the MARS option unlocked – will be available soon.
If you intend to use CAT controlled radios band switching will be automatic.
If not, you will need to select the proper filter manually. This option will be available in special MARS software.
We check all parameters in LAB, running full legal power, and results are given in table below:
This is great news!!!
Thank you Flex !!!
Power Genius XL supporting MARS operation is great news.0
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
