Will DDUtil be required to control PG-XL?
Butch
Member ✭✭✭
Is it safe to assume the Flex 6xxx/PG-XL combination will not require an aftermarket utility (such as DDUtil) to set and control the drive power on each band?
No. It will be fully integrated with SmartSDR with no additional third party software needed for everyday use. There will also be a separate app developed by 4O3A with the ability to adjust settings.
You can use DDUtil if you like but the goal is full SmartSDR integration.
Ria2 -
Thanks Ria. That sounds great.
You would need to set your drive power per band and make sure to save those settings in your profiles on the Flex.
- 375 Community Topics
- 105 SmartSDR+
- 427 SmartSDR for Mac
