LAN remote, no TX audio
Rhett Aultman
Hey everyone,
Well, after a *whole year* off of HF thanks to a cross-country move, I finally got my 6300 out of storage and upgraded to SmartSDR 2.0 for Windows. My goodness, how things seem to have improved!
Anyway, I've been trying to get into using my laptop as the a "remote" on the wifi LAN so I'm not tied to a shack location. Everything has gone pretty good with that, and I can receive just fine, but transmitting is still being a problem. Every time I click the MOX button, I just get a slightly flat **** in the panadapter that does not modulate with my voice. I'm sure there is a setting somewhere that I've simply missed, but I have no idea where. Can someone help me out here?
Best,
Rhett / KI4FWY
Best,
Rhett / KI4FWY
What do you have selected for the input source drop down? (right above PROC button)
If the correct input source is selected, also make sure the "TX" button in the TX Stream box of the DAX Control Panel is blue (click on it to enable) and the gain is turned up, but not compressing.0
Make sure you select PC0
Make sure that once you do the above your default device (click sound icon by windows time... tray icon). Is the microphone input on your sound device.0
There is a setting in the Radio Setup menu to ENABLE waterfall while TXing. Maybe that is what you are looking for.0
I've lost audio several times in a manner similar to this using a hardwired LAN connection with my Maestro. The latest version of SmartSDR has a few annoying bugs. My radio is the 6300.
Turns out this was the right answer. Thanks, guys.0
Huh...well, actually, I might have spoken too soon above. I do have PC set, and I'm pretty sure I'm using the right audio input device in Windows, but I went to check the TX stream and I notice when I key up that the little gauge doesn't move on it, which tells me I'm probably putting nothing into it.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
