What are the correct physical dimnsion of the PowerGenius XL Amp?
Watts - K4QJZ
The Web age and the specification sheet differ as to the physical dimensions and weight. I am trying to plan for Rack mounting in a remote location.
Web page Spec sheet
Web page Spec sheet
- Height:2 6.0" (15.1 cm) 5" H
- Width: 14" (35.5 cm) 13"W
- Depth: 20" (50.5 cm) 17"D
- Weight: 37.4 lbs (17 kgs) 33lbs
From the actual amp in my shack:
H: 6 1/4
W: 14
20 but remember there will be connectors/cables on the back
W: I don't want to disconnect it to weigh it.
Mack
W4AX
Alpha Team1 -
Hi Watts - In another Post Tim mentioned FRS is working on completing a manual for the PG XL. Hopefully we'll see it soon, along with the dimensions. I plan to get PG XL on order before the end of the year, and also need to know the dimensions. Happy holidays! Butch - KF4HR
Thanks, I was afraid it was bigger than I had planned for, I went by the spec. sheet. Given the connectors and cooling would you plan for 23-24' of depth? Again thanks for the quick answer.
I ordered mine as soon as I could, so I am trying to finish the space and power for it. Really excited about having more than 100w now that my Hex beam is repaired and back up. Happy Holidays! 3' of snow today and continuing to come down,
Watts, You only need additional depth for the four PL-259 connectors and the radius bend of the coax you are using . The ethernet and power connector take virtually no room Mack W4AX Alpha Team0
Thanks, Happy Holidays!
Merry Christmas!0
The web page is correct.
Height: 6.0" (15.1 cm)
Weight: 37.4 lbs (17 kgs)0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
