TRANSVERTER AND PANADAPTER DISPLAY
George M.
Hello, I have a 28 to 144 MHz Transverter connected to my 6300 using the transverter output and as far as making contacts everything is fine, except while transmitting the Panadapter stops. Is this normal? If not, how do I get the Flex to display the transmit signal on the Panadapter?
Do you have this enabled in settings? This may be your issue. Otherwise I think xvtr doesn’t display the panadapyer.
Yes, it is normal. Read section 26.4 in the SmartSDR Software User's Guide for the detailed explanation.0
- 654 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
