Is the 2200 / 630 Mtr Selection not available in 6400 / 6600 Series 2.0 SmartSdr units ?
In my 6500 with New 2.0 SmartSdr, the Band select GUI shows 2200 & 630 Mtr selection. On Page 33 of the new 6400 / 6600 Manual it isn't there...  What gives ??
Welcome!
  • Member ✭✭
    edited February 2018
    Yes.  There is 0dbm available on the transverter port for those bands.  You will need to add an amplifier to get to a reasonable power level.
  • Member ✭✭✭✭
    edited June 2020
    probably a older picture then the latest release's of SmartSDR before we had access to those bands
  • Member ✭✭
    edited December 2019
    This is an error in the documentation.  Thanks for pointing it out. I have corrected the documents and the correction will go out with the next release.
  • edited November 2017
    Thanks Dave...  Also on page 61 , the Audio Input selection Is missing the PC, but that may be correct...   not sure... curious...
