DAX, Parallels, and fldigi
DonS
Member ✭✭✭
I have the latest version of Parallels - v13, latest version of fldigi - 4.0.12, and the latest version of SSDR - 1.11.12. Everything sets up fine, however, I am not getting any audio stream to fldigi. fldigi follows the frequency and I can key the radio from fldigi and I do get the TX stream and output into a dummy load. I am using dax channel 1. There is audio on the RX stream but nothing in fldigi. I am sure it is something simple but not sure what. This same setup works fine on a stand alone PC.
Don - kx9q
Don - kx9q
Is DAX on in the transmit panel of SmartSDR?0
Yes0
The other thing I noticed when I looked into the Sound Playback and Recording (windows) only the DAX RESERVED AUDIO RX 1 showed any activity on receive which would be the Playback section of the Sound window which I assume is actually the transmit. On the recording side there was no activity at all on receive.
Don - kx9q
When all else fails remove SSDR, DAX, CAT, FlexVSP then reboot and reinstall. All works fine now.
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
