ref: Unable to move or scale Smart SDR
Steve G1XOW
Lewis and all,
I reported this problem a long time ago. It can also happen on large monitors. Mine is a 43" 4K UHD screen and it does exactly the same thing. See https://community.flexradio.com/flexradio/topics/ssdr-wont-stay-put-on-screen
However, if you have v2 then there is an acceptable workaround. When the SmartSDR frames are un-docked (using the pop-out icon) then they do work correctly and do in fact stay where you put them, and to the correct sizing.
Something is obviously not quite sitting pretty between SmartSDR and W10 drivers but at least for those with v2 we can frig it to work.
Had never this problem
W10 + 34" + 29" + V2.0.19
73 Chris0 -
Forgot to say, this problem persisted through numerous W10 major updates (including 1709 and Creators). It has even persisted beyond at least 2 bare-metal installations of W10 so I am pretty sure its an SSDR vs Intel Driver issue pertaining to the use of higher resolutions.
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 984 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
