some qustion on the 6600m
elan
hi
i have some question is there possibility to add Maestro to the 6600M ?
i cant see the transceiver will have compatible leg or angel on the front ?
why flex not doing it flexible what i mean you can remove the front with cable or non cable to your
operation table and can plug it back if you like one unit ?
but for sure i cant see any leg on the front that cant tilt the radio in any position
73 elan g0uut
73 elan g0uut
Since the 6600M hooks to your network, it should work with a Maestro connected to the network. But, if you don't want a radio with an intergrated panel, get a 6600 non M model and use it with a Maestro like you would with a 6300, 6400, 6500 or 6700. The M model radios are supposed to have feet or a bail.of some sort on the front underside of the radio to allow tilting the front of the radio upwards for a better viewing angle.
WD5GWY2 -
hi James
and thank you very much for the info yes for sure i know there is 2 model
why ? you can just add may be the clip on clip off and insert the front panel with plastic cover
what i was thinking is if you like to add the Maestro you buy 6600m and for sure you can clip on or off
the unit but okay i see the point okay vy 73
elan g0uut/4z4un/dl9fcc0 -
The front of the 6600M is not a Maestro, but it shares the same controls. In order for the front panel to be removed it would need to communicate with the radio some how. this would be a completely different product then what is being offered.
All FLEX-6000M models will work in "native" mode where you use the front panel controls. Or you can use a GUI clients (SmartSDR for Windows, SmartSDR for iOS or Maestro) to control the radio.
All FLEX-6000M models have front feet flip extenders to provide an upwards tilt for better viewing of the front panel.
All FLEX-6000M models are fixed configuration. If you need a portable control surface,m you can use the Maestro.0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
