flex 3000 no cw, from radio jack. CWX page transmits ok, whatto do???
Johnnie
flex 3000, powerSDR 2,7,2. No cw from front jack, CWX transmits ok, what to do???
If you have checked the connections from the key to the jack, then the front Panel connections could be dirty or not making proper contact. You can open it up and carefully check the jack for any sign of corrosion or something pushed in there by tiny hands.....hi
Failing that, its a trip to the service centre.
And make sure you have it setup correctly in Setup. The default database setting should work without change with paddles connected to the radio using a standard 1/4" TRS connector.0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
