Re-packaged Flex 3000
Robert
VE7ZN
Very nice job....0
Robert, just noticed. What is the additional circuitry?0
Mic circuitry, fan speed controller, and an audio amplifier. Have since added temperature sensing fan control (not shown in the pic but mounted onto the audio amplifier board).0
Awesome post, thanks!
I've never cracked open my 6300 but can assure you I've never liked all the noise the constant fan makes. Ridiculous.
It's amazing how much of the rig is the 100W PA and the ATU and LPF.
I'd like this transceiver without the any of those, personally.
Need none of that to feed into the amps I build.
Oh well, probably not much $$ in that for FLEX.
73s
Bob, where do I go to get those mods done........way cool.
David / KE7JHA0 -
I open mine twice a year, to clean the fans and any dust inside. Fan noise is usually caused by dust settling on the blades, changing the airflow over them. One can also use antistaic wipes to slow this process down.
Realy nice work, care to give some more info like what is the name of the casing and how you did all the holes in the back? I would really like to do something like this as I find the initial case not as pretty as it used to be ;-)
So, the fans only spin when the radio reaches a certain temp?
David, I designed and did it by my lonesome.0
The case was ordered from a company in Japan and sent by courier - very reasonable cost and VERY good quality - like most Japanese goods. I designed the panels using FrontPanelExpress software then had them mill them for me. This is a terrific company in Seattle that does very high quality work and very reasonable cost.0
If you want more specifics, email me at VE7ZN at jasero dot com. I'm happy to share the design files with anyone.0
Yup. I've set it to 110F which is well within specs. However, I did use a large heat plate under the chassis which makes a big difference. Rarely do I even get close to 110F. Usually it operates around 87F-95F or so.0
Thanks Pat. With Darrin's (KE9NS) PSDR version it's a great setup and I like it very much.0
Robert, I can't even solder correctly! So could I talk you into doing my radio for me. I'll leave the cost up to you. Please let me know by email:
dkutiej@aol.com0 -
Great job - I was thinking the same. Could you document ? What was the total build cost? Cheers & 73’s ZL1RPL0
Several folks have asked me where I got the enclosure etc., so I will give some basic details here:
NOTE: Doing this, you must take your Flex 3000 completely and carefully apart!
1. The enclosure was purchased from Takachi Electronics Enclosure Co. Ltd. http://www.takachi-enclosure.com. I chose the Takachi MS99-37-35B (Black) enclosure which (JUST) fits everything. I could have used a bigger enclosure which would have made fitment easier, but I didn’t want to go any larger than I had to.
2. I designed the front and rear panels and then had Front Panel Express in Seattle, WA mill them for me (http://www.frontpanelexpress.com/) . They do the engraving and ink-filling for a very professional look. (They are an excellent company to do business with and I can HIGHLY recommend them.) If you want to use my front and rear panel designs, send me an email and I will email the CAD files to you.
3. I also used a .25" thick plate of T-6061 aluminum as a heat spreader/heat sink which mounts under the Flex chassis. (I was going to use copper but the cost was prohibitive and milling is easier with aluminum). The Flex was first fit to the plate and appropriate mounting points established, drilled, countersunk and fitted with the required hardware. Then I figured out where the mounting points for the plate to enclosure should be. These were drilled through the enclosure and into the plate and then I tapped the holes in the bottom of the plate. On re-assembly, the flex is mounted to the plate (thermal paste applied) and the whole assembly is then mounted to the enclosure bottom.
4. There are various connectors that need addressing, including:
• 8 pin mic RJ-45 connector
• 8 pin “Kenwood” compatible mic connector
• antenna connector
• DB-9 serial cable connector
• Firewire connector
• DC input power
There are MANY ways to deal with these and you can decide what works best for you; however, the biggest PITA is the mic connector, which won’t allow you to insert a plug because of its fitment inside the enclosure. I had to remove the existing right-angle PCB connector and install a vertical PCB connector. A bit tricky but it works. I made a small jumper from this new connector to an RJ-45 breakout board (which you can see in one of the pics - under the fan driver board on the left side).
For base operations, I use a Kenwood MC-60 microphone and so I used the appropriate 8 pin connector on the rear panel.
Due to fitment issues in this enclosure, I changed the antenna connector on the Flex chassis to a SMA bulkhead connector and then a right-angle SMA fitting to the coax jumper which goes to the bulkhead-mounted BNC antenna connector on the rear panel.
All the other connectors on the rear panel are self-explanatory.
5. The fans are 60mm x 60mm and are now controlled by a temperature sensor mechanically fitted to the top of one of the RF finals. Once they exceed 120C, both fans come on HIGH and stay on until the temp drops to 110C. This doesn’t take long at all. In my normal operations, the fans don’t come on very often – you really have to be long-winded on SSB or using a lot of power on digital modes (which you shouldn’t be doing anyhow).
6. To improve airflow, you could also put ventilation slots in the enclosure top panel; however, I didn’t find it necessary and it would have simply added to the cost.
Hope this helps those of you who may consider going this route. It was a fun project and I love how it looks and works. As for cost, the enclosure and panels are the biggest expense (Enclosure was $88 + shipping and panels were $158 including shipping (ready in 5 days!). Aluminum plate was about $20 and then you need misc connectors, fans, wire, etc. Great little rig.
Best 73,
Robert VE7ZN0 -
Fabulous - great work - thanks for sharing the details. 73’s0
Absolutely beautiful. Just got a nice used 3000, thanks for the list of materials.
Pat KA4VNM
Oops, I note in my earlier post that I had the fans come on at 120C - which should have read "F". I was trying to express temp in "American" degrees but messed up -
. Recently , I changed my fan temp control circuit and adjusted it to come on at 30C then they either ramp up speed (or not) to get the rig back down to 30C. The fans will stay on "low" which is barely audible to maintain 29C-30C. Much better now.
Question, unrelated to the original post. I have a damaged BNC from shipping and need to replace it. I removed the cover and see that some components seem to be tied to heat sink with screws. I need to pull the board and there is no service manual on a 3000 with instructions for disassembly. Did you need to separate the TRX board from the heat sink or did you just unscrew the boards as one and move them to the really nice new case? I need to get to the BNC on the board side so I can de-solder the old one and replace it. Any tips appreciated. I to am running Kens software and loving it!
Pat0 -
Updated comments re: my repackaging of the F3K:
Further to my last post (copied below) here are some NEW NOTES in bold text
1. The enclosure was purchased from Takachi Electronics Enclosure Co. Ltd. http://www.takachi-enclosure.com. I chose the Takachi MS99-37-35B (Black) enclosure which (JUST) fits everything. I could have used a bigger enclosure which would have made fitment easier, but I didn’t want to go any larger than I had to. If doing it again, I would choose a slightly taller cabinet, perhaps the MS-133-37-35B to incorporate a larger heatsink and alternate fan placement.
2. I designed the front and rear panels and then had Front Panel Express in Seattle, WA mill them for me (http://www.frontpanelexpress.com/) . They do the engraving and ink-filling for a very professional look. (They are an excellent company to do business with and I can HIGHLY recommend them.) If you want to use my front and rear panel designs, send me an email and I will email the CAD files to you. If choosing a taller enclosure (as above), the rear panel would have to be changed slightly to accommodate different fan placement.
3. I also used a .25" thick plate of T-6061 aluminum as a heat spreader/heat sink which mounts under the Flex chassis. (I was going to use copper but the cost was prohibitive and milling is easier with aluminum). The Flex was first fit to the plate and appropriate mounting points established, drilled, countersunk and fitted with the required hardware. Then I figured out where the mounting points for the plate to enclosure should be. These were drilled through the enclosure and into the plate and then I tapped the holes in the bottom of the plate. On re-assembly, the flex is mounted to the plate (thermal paste applied) and the whole assembly is then mounted to the enclosure bottom. If doing it again, I would simply buy and use a larger heatsink. The heatsink Flex used is a complete joke. I would have something with fins at least 1" high and 3/8" thick base. HeatsinkUSA.com offers several reasonably priced alternatives - but probably have to use 2 pieces side by side to cover the full LxW required. I would mount the heatsink inverted so that the bottom cabinet slots could provide some air entry (slots oriented towards front of cabinet) and I'd cut the heatsink in such a way as to accommodate the 25mm deep fans at the rear. there is really no need to have the fans "above the board" as I did. In hindsight, inversely mounting the heatsink and leaving a space of, say 30mm from the back of the heatsink to the inside of the rear panel to allow the fans to be mounted would have been MUCH better.
• antenna connector
• DC input power
5. The fans are 60mm x 60mm and are now controlled by a temperature sensor mechanically fitted to the top of one of the RF finals. Once they exceed 120C, both fans come on HIGH and stay on until the temp drops to 110C. This doesn’t take long at all. In my normal operations, the fans don’t come on very often – you really have to be long-winded on SSB or using a lot of power on digital modes (which you shouldn’t be doing anyhow). I've changed this arrangement. I HIGHLY recommend using Noctua NF-A6x25 PWM fans - they are super quiet and VERY efficient. I use a cheapo PWM fan controller (from Aliexpress $3 or Amazon $10) to control the fans. I've set them on spin at 20% continuously then ramp up as the temp increases. I suspect that if you were using a MUCH better heatsink than the **** Flex one, you would hardly ever see the fans ramp up to 100%. I bet they'd rarely ramp up to 50%.
6. To improve airflow, you could also put ventilation slots in the enclosure top panel; however, I didn’t find it necessary and it would have simply added to the cost. A MUCH better alternative is to use a taller cabinet, bigger, better heatsink (mounted inversely), orient the slots on the bottom cover to the front, and place the fans in between the rear of the heatsink and rear panel.
Best 73,
Robert VE7ZN
I just priced out the case, $268!! I think I'll stick with my old case.
I like this write up and I can see the value of upgrading heatsinks etc. I would make a few extra alterations in that that I would replace the standard mic input with separate PTT and balanced audio inputs/outputs, replace the standard firewire interface with an internal Thunderbolt adapter, and fans with directed flow over the heatsinks for better cooling. I may consider this in the coming months, thanks for the inspiration.0
@KA5BBC How would you do the interfacing from the standart firewire to an internal thunderbolt?
I've been hoping to use a thunbderbolt connector on my laptop to drive my flex 3000 and I just can't find a known good way of doing it.
Wouldn't this work?
https://www.apple.com/shop/product/MD464LL/A/apple-thunderbolt-to-firewire-adapter
Great question!
I have tried , unfortunately Host Controller IEE 1394 does not appear or device manager. My OS is Windows 10 on INTEL NUC. No luck in connecting to my Flex 5000.
Sometime ago I set up an Apple Mini and run Wimdows 10 under bootcamp as my main station computer. Firewire works fine.
Tom
- 338 Community Topics
- 579 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 126 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
