Flex app sees the radio but wont connect.
Howard Koenig
IOS Flex app sees my 6300 but wont connect. I am using softether vpn and have opened the following ports.
Flex radio TCP/UDP 4991-4992
Softether ports on the PC UDP 500 4500 1701 TCP 443 5555
I have full WAN access to the computer.
I am 1500 miles away.. Please , any help? Thanks
If the network that the flex is on has a 192.168.1.x IP, then there could be a conflict. I would suggest renumbering the network since a lot of public and home wifi is 192.168.1.x. That is the most common problem.
Ria0 -
UPD 500 4500 and 1701 are for an L2TP VPN connection from IOS. 443 and 5555 are for Softether connections.
How are you connecting to the radio? With the VPN active or not active. Or, are you using SmartLink?
Are there port forwards on your router for 4991 and 4992? You didn't say.
Mike0 -
everything was working fine, until the router was replaced the other day.
I am out of state for the time being. yes 4991 and 92 are open. the app discovers the radio but wont do anything. I have softether running havent changed anything.
just noticed cant connect to the vnc either although the ports are open for that also.
im not sure what you mean..I have the IP's listed correctly and never had any problems.. just a new router.. I wouldnt know how to change them.
Yes, if the router was replaced I can see this happening if not all the settings weren't copied over.
If you are using Softether, you don't need 4991 or 4992 as SmartLink is not required. So, that is not part of the problem or the solution.
If the router changed, did it change your external IP address?
Can you connect via SmartLink and no VPN?
Mike0 -
Ria's comment is worth looking into. If you replaced the router the default IP range for the DHCP server could have changed, and could be the same as your local network. If your local network is, say, 192.168.1.x and your home network is 192.168.1.x you're going to have problems. I suspect the radio is discovered by MAC address, which is why that works, but IP connection will fail with the above scenario.
Doug K4DSP1 -
This stuff boggles my mind.
Just tried another program to try and access . but it too sees the computer but wont connect
I would be happy to let you teamview if you have the time for that.
I am not able to do that as a Flex employee due to liability issues. Sorry. Someone else might be able to though. It does sound like all your IP addresses changed with the new router. This is to be expected as normal operation. There are solutions to prevent that from happening in the future when you plan out your network. Mike0
Thanks anyway Mike..
Not sure where I would find that info. Or what would need to be changed
interesting.. I just had it working. then it stopped again... hmmmm. I rebooted the pc and for a few minutes had an active session with the radio. now it is back to not working. I thought I got it working but guess not.. sigh
Check what IP the radio has. Chances are if it's 192.168.1.x it will be in conflict with whatever remote network you are on.
You can also see the IP in the chooser. Hover over it and you'll see it in a black box.
The fact that you just got a new router makes this scenario I described extremely likely since the default setting for most of them is 192.168.1.x
The procedure to change the LAN IP network numbering varies with the router. If in doubt, ask a networking expert near you to help you...
Doug, you are correct. The radio discovery is via UDP broadcast packets. It doesn't matter what subnet the radio is set to. SmartSDR will "see" the radio. However if it is not in the same subnet or somehow able to reach the network SmartSDR cannot establish a control connection which is via TCP.
Ria, Could he possibly VPN into his local network and change the settings on his router without locking himself completely out of the VPN after rebooting the router?
I'm not sufficiently experienced with Softether.net to know if the remote server management would allow him to make some changes before the reboot that would allow him back in....
Or perhaps using Parallels Access, which I DO have, and is not bound by the router's subnet problem, as far as I know.
Just a thought.0 -
The best way to do it is to use TeamViewer which will automatically reestablish a connection. OR he can open up the WAN side of his router and access admin through there but some routers disable that. I might even offer to help him if he wanted. It won’t take me very long to do.1
Thanks everyone. I got everything working again. Not quite sure what I did, but sometimes that's the best way I guess. All OK now. Been working for the last few hours and working many European stations. Having a blast once again. I hope this doesn't happen again... at least not for a while.
73!
If you have 1 computer inside your network, then you can fix the rest, and it seems you can with TV. Ria has a good offer here and I am sure if she takes her time, it might take 5 minutes.
Oh, and a bottle of wine!
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
