FT8 WSJT-X ADI v1.8 RC1 Log File is not recognized MacLoggerDX version 5.62
Michael Aust
Been on FT8 working 100's of Stations
Seems the log file in WSJT-X v1.8-rc1
has a log file but cannot import it into
MacLoggerDx then to upload new stations
into ClubLog
Any idea's
WB6DJI
Example of log file from wsjt-x below
Do I need a Parser to convert to proper *.adi format
2017-10-10,00:11:00,2017-10-10,00:12:45,JS2AGG,PM84,18.100978,FT8,-22,-15,,,2017-10-10,00:16:00,2017-10-10,00:17:15,JR3IIR,PM74,18.100978,FT8,+01,-02,,,
2017-10-10,00:19:30,2017-10-10,00:20:45,JH3CUL,PM74,18.100978,FT8,-08,-04,,,
2017-10-10,00:22:00,2017-10-10,00:24:15,JH1XOX,PM95,18.100978,FT8,-19,-13,,,
2017-10-10,00:25:30,2017-10-10,00:26:45,JR1USO,PM95,18.100978,FT8,-13,-13,,,
2017-10-10,00:36:00,2017-10-10,00:37:15,JK1IQK,QM05,18.101034,FT8,+01,-15,,,
2017-10-10,00:45:15,2017-10-10,00:45:15,VK4FNQ,QG39,18.100831,FT8,-17,-12,,,
2017-10-10,00:50:30,2017-10-10,00:51:45,JA3DBD,PM74,18.100831,FT8,-13,-19,,,
2017-10-10,00:56:00,2017-10-10,00:57:15,JH1XVQ,PM94,18.100831,FT8,-05,+06,,,
2017-10-10,01:00:00,2017-10-10,01:04:15,JA6WHC,PM52,18.100831,FT8,-13,-23,,,
2017-10-10,01:15:30,2017-10-10,01:15:30,3D2AG,RH91,18.101223,FT8,-18,-09,,,
into ClubLog
Any idea's
WB6DJI
Is there no capability to export ADIF from the WSJT-X software?0
It creates a log file but it seems the format can not be
brought into N1MM or MacLoggerDX 5.62
P.S. : Using my Flex6700 with wsjt-x v1.8 rc1
Look for JT-Bridge software (by SM0THU). It will allow automatic import of WSJT-X contacts into MacLogger DX.
Also, in the log directory for WSJT-X there are actually two log files. One is wsjtx.log and the other wsjtx_log.adi - can you confirm the .adi is the one you're trying? It looks like you posted from the .log file.2 -
In my directory this is what I see
I have been using JTAlert-X with WSJT-X to create a log file, just use the setting in JTAlertX to create a generic ADIF file. Then I import that into MacLoggerDX, and haven’t had any problems. I am using v6.14 of MLDX, but I wouldn’t think that is an issue. Using WSJT-X 1.8 rc2, and JTAlertX v2.10.3 I just did it this weekend and imported a bunch of QSOs into MLDX and then updated the info in them with callbook, uploaded them to QRZ and LOTW automatically. All worked no problem. I did see that WSJT-X creates a log file too, I did not try importing that one just used the one from JTAlertX. Hope that helps! Justin KL2D1
From WSJT-X, select File, then "Open log directory." Should see the adif file. By the way, why not use WSJT-X for Mac if you're using MacLoggerDX?
Recent MLDX versions will also upload to QRZ, LoTW, eQSL, and ClubLog automatically.1 -
George - Thanks for posting this! I didn’t know it would auto import into MLDX, I am definitely going to try this. My method was a bit klunky....1
My remote station is in different QTH than where I have MacLoggerDX home station
Mike0 -
WSJT-X does create a log file. I know where it is on a PC, but not on a MAC. (or, am I missing something?)
I have imported this log into several programs. If MacLogger can't handle it, you might want to ping Don Agro at DogPark. I'm sure he can resolve it in moments.
BTW, you should update to RC2 as the protocol changed a bit.
http://physics.princeton.edu/pulsar/k1jt/wsjtx-doc/wsjtx-main.html
The log filewsjtx_log.adi
is updated whenever you log a QSO from WSJT-X (but note that it can also be erased from the file menu). You can append or overwrite this file by exporting your QSO history as an ADIF file from another logging program. Turning Show DXCC entity and worked B4 status off and on again will cause WSJT-X to re-read the log file. Very large log files may cause WSJT-X to slow down when searching for calls.
When I copy the file wsjt_Log from one PC to another
The original Remote computer Windows 8.1 say it is an AEOMI file,
Then if I past this file into my Windows 7 computer it say it is a .adi
Will try to upload into MacLogger DX 5.62, will back up my original .adi
file from MacLoggerDX 5.62 in can I destroy my Log in MacLoggerDX
Yes, using rc2, works a lot better
Mike0 -
EVERYONE !!!!
Thanks, uploaded Fine,now I can get rid of paper log
WB6DJI1 -
Using wrong version of MacLoggerDX.0
What does this have to do with a FLEX radio?????
Bob, N0IS
Might this question be best answered on the WSJT-X forums?
BTW, I changed the post from a problem topic to a question because this isn't applicable to FlexRadio products.1
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 258 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 12 Aurora
- 148 FLEX-8000 Signature Series
- 904 Maestro
- 50 FlexControl
- 863 Genius Products
- 305 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 713 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 935 Third-Party Software
