Strange problem with SmartSDR iOS on iPad Mini 4
I get a constant pumping sound when I use the iPad mini4 unless I turn the VOX on. Once the VOX is on the pumping sound completely goes away and everything is normal. If I disable the VOX the pumping sound returns. I don't get this on a much older iPAD nor do I get this problem with my iPhone6. Not sure if it's my Mini 4 or a strange problem with the SmartSDR iOS.
Also, the VOX works normally when it is enabled.0
Jim,
can you please check / try the following:
- When connected, on the right menu, can you please double check if iPad has been selected for Mic input
- Can you change the "Microphone volume adjustment" in Settings to a low value (e.g. -2)
Please let us know if this changes the pumping sound situation.
Marcus, DL8MRE
Hi, Marcus,
The only thing that changes the continuous popping sound is the enabling/disabling the VOX button. I did further checking and it does not happen if I use an Asus router, but it happens if I use a Linksys 1900 AC. Also I have a WiFi extender (using it with either the Linksys or Asus) and if I select the extender instead of the router, itself, the popping goes away. If I come in from the outside, like using Verizon LTE, the problem goes away. It's only when I connect directly to the Linksys router does this occur. I am not sure I will ever pin this problem down. I am not sure if it's a problem. Another interesting point is that I do not get this popping using SmartSDR for the PC using the PC either directly connected to the router or wirelessly.
Jim, K6QE
Jim,
this is interesting but shows that this is rather a network issue than an App issue however, it is strange as you wrote that this also only happens with your iPad Mini. Can you confirm this still after your finding regarding the router?
Another thought: If possible, try to solely enable Wifi on 5GHz (and disable 2.4GHz) on your WiFi router and vice verse to see if this makes any difference.
Marcus, DL8MRE
Hi, Marc,
I have all ready tried disabling 2.4 GHz., with 5 GHz. running and reversed the condition. The same problem. Seems not to be related to the frequency. There is something weird going on between the mini and the Linksys and I just can't seem to pin it down. I just updated to the latest iOS version 11.0.2 and that made no difference. Life is to short to ponder this any further. II anything should surface or change, I'll let you know. Sorry to have bothered you with this **** symptom. However, I use the mini with other programs like Pandora, Slingbox, Tunein radio, and everything works perfectly.
Jim, K6QE
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
