What does the "low bandwidth" on the Maestro do?
RTFM (Read the Flex Manual)
SmartSDR Software Users Guide, section 7.3 Using SmartLink
Alternatively, use the Low BW Connect button to connect to the radio. This option is only available when connecting to a SmartLink connected radio. Using this instead of the Connect button starts the radio with a single Panadapter at a low refresh rate and with a single Slice Receiver allowing modest Internet connections to run SmartSDR remotely.
Thanks Tim.0
Hi Jim,
I did not use this function for my mobile operation yet.
From my tests, I could only see half of the transfer rate vs. the standard connection.
Instead, I´m using the standard connection type (was also more stable for me) and to minimize the total data rate, I always go down with the display update rate settings (Rate + FPS).
With this approach, I could reduce the total bandwidth around 100kB/s (and less).
73, de DH1RK, Ruediger0 -
Adjusting the rates after connecting assumes that you can initially connect using the higher data rates. This is not always the case, hence the option to connect initially with a lower bandwidth option.0
- 352 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 978 Third-Party Software
