Windows Time Sync with GPS PPS
joe camilli
What Windows time sync client that supports GPS PPS are folks using?
Joe N7QPP
Joe N7QPP
BKTTimeSync supports it.
http://www.maniaradio.it/en/bkttimesync.html
Note that you cannot use the FLex GPSDO for time sync. Has to be a USB GPS or similar.
Ria
BKTTimeSync looking at it. Where do you see it uses PPS?
My mistake. I don't really see it having that.0
Unfortunately I have found that synchronizing a Windows computer with a GPS with PPS signal doesn't work well. Even with specialized software. for any printer issues you can visit the epson printer error code 0x97 and get the experts advice
I had a heck of a time running ft8 on my icom7100. It was working until I went to a rear grid POTA. Then nothing. Not until I got home did I figure out that it was the time problem. I ran the BktTimeSync program and FT8 came alive. Working DX with 100watts and little Tarheel on the RV. I need to get back to EM61 before the end of the year.
roger
na4rr
These a*holes are getting really persistent!0
The common reasons for happening this Epson Printer Error Code 0x97 includes due to an internal hardware issue, which occurs due to motherboard fails, when the printer stops printing, jammed paper damaged system files, corrupt files, and missing files, etc.
I have been using a program called NMEATime 2 Sync by VisualGPS.
http://visualgps.net/#nmeatime2-content
I have an external BG7TBL GPSDO and have the RS-232 output running over to one of my computer USB ports. (The GPSDO also feeds my 6600 at the same time via the sma connector) NMEATime runs in the background and has kept my computer time synced 24/7 without internet allowing me to run WSJT-x without issue for over two years now! On WSJT-x i'm always within a DT of .1 -.3 sec with most stations. I've also used it portable.
Cal/N3CAL
I use the same software and GPSDO. In fact, I think it was a post you made a year or so ago that got me to purchase this setup. It works very well.
The Canon printer error code 5b02 indicates that you have a complete ink tank. Error codes and messages are one of the issues with Canon printers. There are different types of these error codes and messages such as error code 5b02, 5800, 5B00, 5200 and many more.
Users will generally come across this error when they are trying to update their Windows 10 in HP devices. As most of the users come under the grip of this problem, it is advised well in advance to fix Windows update error 0x80248007 in HP device
- 650 The Flea Market
- 153 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
