Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
Flex 6300, SSDR v1.10.16, N1MM
I finally broke down and upgraded from SSDR v1.6.17 to v1.10.16. I fired up N1MM to set up for the RTTY contest and N1MM and the Flex are not talking to each other. Ports for which I had set for N1MM (COM4 for radio and COM10 for CW/Other) no longer appear in CAT v1.10.17. So I changed the radio to COM7, which appears in CAT, and changed to COM13, newly created for CW/Other. I was unable to get COM4 and COM10 as port choices when trying to reset ports.
When I fire up N1MM it shows as the Process for these two com ports in CAT BUT when I start N1MM the 6300 goes to transmit and will not stop until I shutdown N1MM. N1MM is not reading the radio frequency. I can't begin to know if MMTTY will work until I can get the radio and N1MM talking to each other.
Looking like another case of 'don't fix it if it ain't broke' but that's where I am. I just hate changing/upgrading when everything is already working. Any suggestions for fixing the setup would be appreciated.
73 from the desert.....Fred/NA2U
- 67 Community Topics
- 1.9K New Ideas
- 118 The Flea Market
- 5.3K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 84 SmartSDR for Mac
- 143 SmartSDR for iOS
- 149 SmartSDR CAT
- 66 DAX
- 278 SmartSDR API
- 7K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 553 Maestro
- 14 FlexControl
- 721 FLEX Series (Legacy) Radios
- 147 Power Genius Products
- 116 Power Genius XL Amplifier
- 10 Power Genius Utility
- 21 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 88 Remote Operation (SmartLink)
- 50 Contesting
- 127 Peripherals & Station Integration
- 61 Amateur Radio Interests
- 402 Third-Party Software
@Fred - a few thoughts:
1). it is always better to check through your settings and jot them down before any upgrade. Personally I do Screen Captures for post-upgrade reference. Also do the profile exports and follow the release notes.
2). avoid upgrading to anything other than the latest (Version 1 of Smart SDR is at 1.11.12) as the latest has the most "fixes" in it. Unless there is a special reason to jump to a version between your old version and the very latest, you end up doubling your time and troubles making small steps.
3). third party software (like N1MM+) usually need to be carefully managed - again capture those settings and make sure you present version is compatible with the SmartSDR upgrade. Often you have to upgrade the third party software at the same time to maintain compatibility.
You may have done all this, but looking at your present pickle:
1). Go through you old N1MM install & configuration notes, of if you didn't make any follow their setup guide to work with SmartSDR.
2). Check for Com Port issues, as some upgrades of SmartSDR include driver & cat upgrades. You may have crossed one of those Rubicons.
3). If nothing sensible really makes sense, consider opening a help ticket as Dudley & the Gang are really awesome if bailing a guy out.
Good luck and 73
Steve K9ZW
I may be just silly but I have learned with software do not upgrade unless you have to. Windoz, Foxpro, Quickbooks, have taught me this. I am still on the fence with my Flex radios. With all the problems I have seen with upgrading to the 2.x of the Flex software I have decided to leave my 6300's on the older stuff so I do not have to deal with the licensing problems and when I get my 6400 I will try it out and see what happens.
Upgrades are like sticking your finger in a light socket and wondering if its turned on or not.
The new SmartSDR CAT most likely assigned new com ports as the old ones were already allocated. I use one of the various utility programs to delete the unused ports before upgrading my CAT new software versions.. I use COM_Name_Arbiter_Setter.exe but there are many out there, use Google to find one.. Windows will always choose new com ports as the old ones still how up as allocated.
As others stated always best to keep up to date with the latest versions available. 73s Jim K4JAF
I'm going back in to try again but optimism is alluding me.....
73 from the desert......Fred/NA2U
1. When I say the Flex switches to transmit when I start N1MM I find that the LED on the rig turns RED but there is no power output.
2. Except for the Flex Control USB Control Knob (COM3) ALL COM ports indicate on their Properties tab in Device Manage that "this device is working properly" (on the General tab) yet
review of the Resources tab reveals "This device isn't using any resources because it has a problem" Each virtual port reads the same on these two tabs.
What?
73.........Fred/NA2U
I always make screens captures so I know later how things were set. I guess that won't work with SSDR.
Thanks all for suggestions.
73 from the desert...........Fred/NA2U
This may have necessitated the recreation of your COM ports.
Ken - NM9P
