Looking for the best TRANSVERTER for my 6700. Any suggestions?
David Allday
2
What band? Down East Microwave makes some excellent products that are easy to interface with the Flex-6k radios.0
need to knot witch band you what to operate
personally i like kuhne-electronic.de , Down East Microwave was also no so bad
I should point out, DEMI is great and very fine quality, but usually take months to get. Great service though, and friendly staff. Just takes a while.1
"KIT" option is much faster delivery ,but need to assemble it yourself ,no to dificult
just not forgot to tune it for Best Signal over noise instead of just "Gain"0 -
IMHO best on the market is DB6NT 144-28PRO.
http://shop.kuhne-electronic.de/kuhne/en/shop/converter-transverte/transverter/TR+144++PRO++Transver...
Demi is also very good.
Very interesting is Anglian
http://www.g4ddk.com/Anglian3techdes.pdf
but i use old Microwave Modules MMT 144-28 and MMT 432-28S
http://www.radiomuseum.org/r/microwavem_linear_transverter_mmt_14.html
http://www.radiomuseum.org/r/microwavem_linear_transverter_mmt_43.html
Last month i tested UT5JCW 144 MHz transverter.
This is simply and cheap construction.
Best regards, 73
Jerry HF1D
We don't have much 2m SSB activity here in the Phoenix area. I sort of gave up on it. There are the occasional VHF contests and once a week there is the SWOT group but that is a very short net. Other than that, I can call CQ on 144.200 for days on end and never have anyone return. For me it just isn't worth the effort.
The nice thing about the 6700 is that it has 2m built in. All you need is the DownEast amplifier. This will give you ALL of the 2m band so you can use it on the local repeaters or 2m FM Simplex as well as on the lower SSB portion of the band. A transverter on the other hand will only give you 144-146.
You would think that with a few million people living in the area there would be more folks on 2m SSB. I think the main drawback for most folks is that SSB folks use horizontal antennas and the FM group which use mobile, repeaters etc., all use vertical antennas. There was some talk here in the valley to try to get a group on 2m SSB using existing vertical antennas but I don't think it ever got much interest.
I sure do miss the 2m SSB days though!1 -
Of course there is no need for a 144mhz transverter on the 6700 as it is already capable of transmitting/receiving on 144mhz, all you need is a linear amplifier with a 10mw input. DEMI make one as does Bert PE1RKI.0
Without a doubt!
- 384 Community Topics
- 646 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
