The S-meter and the RF power meter doesn't seem to work when using 2 meter transverter.
John Pfeifer
John Pfeifer Member
edited September 2017 in FLEX-6000 Signature Series
I see no mention of this here, but possibly another bug, The S-meter and the RF power meter doesn't seem to work with version SmartSDR_v1.10.16 or SmartSDR_v1.11.12 while using the transverter has this been reported or fixed in the SmartSDR_v2.0.17 or any other release yet?
  • John Pfeifer
    John Pfeifer Member
    Or is this a transverter issue?
  • Tim - W4TME
    Not a bug.  The circuitry for power measurements is not designed to measure milliwatt power levels from the XVTR port.
    And the S-meter is working for me in XVTR mode.  The signal level input on the XVTR port (commom IF configuration on the 6300) is displayed on the slice S-meter.
  • John Pfeifer
    John Pfeifer Member
    I wonder what I'm doing wrong then as I only use one slice for the XVTR port for the 2 meter transverter and the S-meter isn't working on mine, thus my post.Can you elaborate how this is done other then it's working for you.Thanks
  • Tim - W4TME
    I do not do anything other than set up the band in the transverter form and connect the xvtr to the XVTR port with a PTT cable.  It just works.
  • John Pfeifer
    John Pfeifer Member
    Are you by chance using the
    $75 Ukrainian VHF Transverter with the Flex-6000 SDR and SmartSDR by K4DSP?
  • John Pfeifer
    John Pfeifer Member
    Never mind, I found the problem, now I'll have to find out what the RF Gain box is for in the Settings, I had a number other then 0.0 and it was way to high, thank you anyway. S-Meter is now working.
  • Tim - W4TME
    Glad you discovered your issue.  73
