Did 2.0.19 get pulled from the home page on the FlexRadio.com Website?
Jay -- N0FB
Looks like the 2.0.19 release link from the www.flexradio.com home page has reverted to the 2.0.17 links. The 2.0.19 installers are still available in the download section of the website. Was this intentional? Should we not upgrade to 2.0.19?
It shows the 2.0.19 announcement for me along with the 1.11.12 announcement. You might want to clear your cache to get the latest version of the FlexRadio home page.0
V2.0.19 shows up when I checked, both under FLEX Signature Series SDR (FLEX-6000 Family & Maestro), and also under SmartSDR for Windows. (I assume this is the same file.)
what is the diff from 2.17 to 2.19?
Bill
Just a guess based on the changelog and release notes for 2.0.19.
They both mention that 2.0.19 will be compatible with the new Maestro hardware.
I figure it would probably be necessary for the 6XXX-M models to have a version of SmartSDR that's compatible with their displays. Releasing the changes ahead of shipping the 6XXX-M and then using it with the existing 6XXXs should allow compatibility and stability testing. SmartSDR has to work with the older 6XXX's and the new 6XXX-M's. Getting the new hardware and it's new software out to the alpha testers soon is probably a good, and necessary thing.
73 Jay / NO5J
SmartSDR 2.0.19 was released to update the Maestro code with changes necessary to support the latest revision of the Maestro hardware. SmartSDR for Windows and for Maestro are always released together and always share release numbers. SmartSDR for Windows 2.0.19 was released because the Maestro code is needed now. The changes to the Windows code were minor.
If you don't need the Maestro update, you can probably stay on 2.0.17 for now.
I disagree with Dave's advice.
There are a few bug fixes in 2.0.19 (especially one for CAT). And if you need support, we require that you are running the latest released version of SmartSDR before we begin any troubleshooting activities. It is always best to be running the latest version of software and firmware for your FLEX-6000.2 -
I rescind that comment. Sorry, Tim.
No problem, Dave.0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
