MARS Operations with SmartSDR
edited June 2020 in New Ideas
I have created a document for MARS operators that helps configure the MARS software for use with SmartSDR. If you are a MARS operator and would like a copy of the document, please let me know.
2 votes
Open for Comments · Last Updated
Welcome!
«13
  • Member
    edited February 2020
    Phil could you send that to me for our EOC. We have some equipment that Air Force and TxARMY MARS uses from time to time. I also have the secret code so if you are worried about that no problem. I have it. You can e-mail it directly if you need to. eric.gildersleeve (at) dentoncounty.com
  • Member ✭✭
    Yes, would appreciate receiving a copy.
    73/gus
    Dr. Gus Lott
    KR4K  AFA6GL
    gus@kr4k.org
  • Member ✭✭
    edited August 2017
    I just sent you a copy.
  • Member ✭✭
    edited May 2020
    Hi Phil, I would appreciate access to your document. I can decrypt if necessary. My contact gonzo a ai1w.com Thank you!
  • Member ✭✭
    edited August 2017
    I just sent you a copy. THe document does require a secret code to open :)
  • Member ✭✭
    edited August 2017
    On its way.
  • Member ✭✭
    edited August 2017
    Phil,
    Could you please send to rhwarner@me.com
    Rodney
    AAA6RD
  • Member ✭✭✭
    edited November 2019
    I'm in the process of getting into Army MARS here. Figured it would be good to give back since I have a servicemember and a veteran in my family. I'll reach out once I'm in.
    Ria
  • Member ✭✭
    edited January 2019
    Would appreciate a copy
    jeff_sperley@sperley.us    W7YJS
  • Member ✭✭
    edited August 2017
    Ria,
    Welcome to the club and let me know what I can do to help you.
  • Member ✭✭
    edited August 2017
    On its way...
  • Member ✭✭
    edited August 2017
    On its way Bernie.
  • Member ✭✭
    edited August 2017
    Phil, I messsed up email - it's jeff@sperley.us - his MARS call is aar0pk
  • Member ✭✭
    edited August 2017
    Resent :)
  • Member ✭✭
    edited August 2017
    I would appreciate a copy also.
    Mike@MeeksPlace.com
  • Member ✭✭
    edited August 2017
    On its way Mike.
  • Member ✭✭
    edited August 2017
    Phil,
    I would vey much appreciate a copy as well. My email is sjcatani@gmail.com.
    Steve
    aaa4ga7
  • Member ✭✭
    edited August 2017
    I just sent it to you Steve.
  • Member
    edited August 2017
    Please send me a copy.
    tom.hammack@gmail.com
    AFA4UV
  • Member
    edited January 2020
    Really appreciate a copy.
    Bill - W2BWL / AFA2AY
  • Member ✭✭
    edited August 2017
    I sent it to the email address you have listed on QRZ.com.
  • Member
    edited October 2017
    Phil, pse send me a copy of the Mars Software...****  w4ntg@cox.net...tnx
  • Member
    edited December 2019
    i'am a CFARS member, my number is CIW-709, this is the canadian version of MARS, if the document can help me i will also need a copy please mab@cableamos.com  Thank's  VE2MBT/CIW-709
  • Administrator, FlexRadio Employee admin
    edited September 2017
    Please submit a support ticket via our HelpDesk (https://helpdesk.flexradio.com) so we can assign you a case number to address your request.
    For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://helpdesk.flexradio.com/hc/en-us/articles/202118688-How-to-Submit-a-Request-for-Technical-Supp...
    Once the support ticket is submitted, a support engineer will be in contact so we can work on the issue.  Make sure to include your product's serial number
  • Member ✭✭
    Copy please... dlwarnberg@gmail.com
  • Member ✭✭
    A 6300 still can not be wide banded for MARS or CAP is that correct?
    Correct.
  • Member
    Hello,
    i already have my FLEX6500 with the patch for MARC/CFARS extended coverage, once FLEX received my certificate, installing the provided patch was a easy job,  My understanding was that Phil, WG5D was offering a document to use software or external device, like PACTOR modem tu use on flex with MARS operation.
  • Member ✭✭
    edited May 2019
    Can anyone that got a copy pass it along?
    Army MARS here, region 4
  • Member ✭✭
    I just sent you a copy :)
