DAX error
Richard Thompson
I'm running Windows 10 64 bit and after a windows 10 update DAX came up with a error.
I fixed the problem.
Go to search and type in CMD and run as Administrator. Uninstall the DAX drivers and install them. then reboot. It fixed my DAX problem
cd Program FilesFlexRadio SystemsSmartSDR v2.0.1764-bit DriversIQ_DAX
cd Program FilesFlexRadio SystemsSmartSDR v2.0.1764-bit DriversRXAudio_DAX
SmartSDR_RX_DAX_uninstall.bat
SmartSDR_RX_DAX_install.bat
cd Program FilesFlexRadio SystemsSmartSDR v2.0.1764-bit DriversTXAudio_DAX
SmartSDR_TX_DAX_uninstall.bat
SmartSDR_TX_DAX_install.bat
cd Program FilesFlexRadio SystemsSmartSDR v2.0.1764-bit DriversMICAudio_DAX
SmartSDR_MICAUDIO_DAX_uninstall.bat
SmartSDR_MICAUDIO_DAX_install.bat
the problem was to put the correct SmartSDR V number in.
In the procedure that describes doing this process, https://helpdesk.flexradio.com/hc/en-us/articles/204017069-How-to-Manually-Re-Install-DAX-Drivers
It states...
This procedure assumes you are running on a 64-bit operating system. If you are using a 32-bit version of Windows, you will need to change the directory path to replace 64-bit Drivers with 32-bit Drivers.
In the example below SmartSDR is version 1.6.21 is used. Make certain you are running this procedure from the latest SmartSDR for Windows application folder installed on your PC.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
