MARS Operations with SmartSDR
Phil could you send that to me for our EOC. We have some equipment that Air Force and TxARMY MARS uses from time to time. I also have the secret code so if you are worried about that no problem. I have it. You can e-mail it directly if you need to. eric.gildersleeve (at) dentoncounty.com0
Yes, would appreciate receiving a copy.
73/gus
Dr. Gus Lott
KR4K AFA6GL
gus@kr4k.org0 -
I just sent you a copy.0
Hi Phil, I would appreciate access to your document. I can decrypt if necessary. My contact gonzo a ai1w.com Thank you!0
I just sent you a copy. THe document does require a secret code to open
On its way.0
Phil,
Could you please send to rhwarner@me.com
Rodney
AAA6RD
I'm in the process of getting into Army MARS here. Figured it would be good to give back since I have a servicemember and a veteran in my family. I'll reach out once I'm in.
Ria2 -
Would appreciate a copy
jeff_sperley@sperley.us W7YJS0 -
Ria,
Welcome to the club and let me know what I can do to help you.
On its way...0
On its way Bernie.0
Phil, I messsed up email - it's jeff@sperley.us - his MARS call is aar0pk
Resent
I would appreciate a copy also.
Mike@MeeksPlace.com
On its way Mike.0
Phil,
I would vey much appreciate a copy as well. My email is sjcatani@gmail.com.
Steve
aaa4ga70 -
I just sent it to you Steve.0
Please send me a copy.
tom.hammack@gmail.com
AFA4UV
Really appreciate a copy.
Bill - W2BWL / AFA2AY
I sent it to the email address you have listed on QRZ.com.0
Phil, pse send me a copy of the Mars Software...**** w4ntg@cox.net...tnx
i'am a CFARS member, my number is CIW-709, this is the canadian version of MARS, if the document can help me i will also need a copy please mab@cableamos.com Thank's VE2MBT/CIW-709
Please submit a support ticket via our HelpDesk (https://helpdesk.flexradio.com) so we can assign you a case number to address your request.
For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://helpdesk.flexradio.com/hc/en-us/articles/202118688-How-to-Submit-a-Request-for-Technical-Supp...
Once the support ticket is submitted, a support engineer will be in contact so we can work on the issue. Make sure to include your product's serial number0 -
Copy please... dlwarnberg@gmail.com0
A 6300 still can not be wide banded for MARS or CAP is that correct?0
Correct.0
Hello,
i already have my FLEX6500 with the patch for MARC/CFARS extended coverage, once FLEX received my certificate, installing the provided patch was a easy job, My understanding was that Phil, WG5D was offering a document to use software or external device, like PACTOR modem tu use on flex with MARS operation.
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
