2 meter duplex on xvtr, Flex-6300, SmartSDR v2.0.17 doesn't work
Craig Haggerty
Hello, I've connected my Ukrainian 2 meter transverter to my Flex-6300. It seems to work fine on simplex, but despite changing the OPT settings to + or -, and the Offset frequency accordingly, there is no change from the receive frequency on transmit on the panel, and no signal is transmitted. Am I missing something or is this a v2.0 bug?
Receive and settings:
Transmit:
Transmit:
I don't have a transverter to test with, but have you been able to try it under v1?
mike
It looks like your offset is set to 600 MHz. It should be 0.6 MHz. I just checked with the same transverter here using SmartSDR v2.0.17 and I can access the local repeater with no problems.
Doug K4DSP
Nice catch.0
Yes, nice catch :-) I thinking in KHz instead of MHz, duh! That being said, 600 MHz is the default onset, maybe that should changed...0
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
