I would like to know how you share smart link with another user
KB4HL
I would like to share my 6300 with a friend and he would like me to be able to access his 6700. It this possible with smartlink. Thanks for any input.
Yes. You both have to use the same login and password.
Using the same credentials is not a great solution. I hope FRS implements a more secure and modern way of credential management and the current implementation is just temporary.
Andy
KU7T
The risk is very low, as you are sharing a unique login with your buddy if you do an email login. It is as about secure as you can get without making it too complicated.
If you need to lock out your buddy, you just change the password. He changes on it and locks you out, you just do a password reset or de-register the radio and start over if required.
While not perfect, this is a very valid method of sharing your radio.
Besides, what is the worse that could happen?0 -
When the Multi-User feature is added to SmartSDR v2.0, it will be extended to include SmartLink so credential sharing will not be necessary.2
Thanks Tim will that be in the next 2.0 update ?
I suspect the next 2.x update will include initial support for the new FLEX-6400, FLEX-6600 and PowerGenius XL along with some bug fixes. But Multi-User is on the immediate horizon.0
- 375 Community Topics
- 103 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
