SmartSDR V2.0 and Hotspots
Bob G W1GLV
I found out yesterday that hotspots and smartsdr v2.0 do not play nice. The hotspots I'm referring to are the AT&T and Straight Talk. They do not pass UPD data, all I got was smartsdr panadapter with no spectrum and no waterfall. Does anyone know of any hotspots that perform well? Thanks.
From experience using the hotspots with remote cameras for work we have had to use the SIM card in most cases with a 3rd party device such as a Cradlepoint. This way you have actual router controls.0
my Verizon Netgear MiFi works great, I have also used it on my Verizon Samsung S7 having it's hotspot turned on.
I haven't tried it on AT&T but would be interested in your results if you get it to work as I might be switching services to AT&T but not if it has problems with UDP.
Also have you tried EchoLink it uses several UDP ports to see if it is actually the hotspot router blocking them or something else is going on.
A lot of hot spot Routers I have had from Verizon DO have a built in Router, try connecting to the hot spot with a computer, usually @ 192.168.1.1 and admin as your login ID with your WEB browser, your wireless password should be the router password, poke around in it and see if you can get into the port forwarding setting and see if you can change it to pass the ports or have a DMZ IP setting.
Hope this helps
73's
Bret
WX7Y
Some mobile ISPs do give problems. T-Mobile is one of them. ATT, not so sure.0
I also found out about T-Mobile trying an Alcatel LINKZONE
Using my Samsung GS 5 as a Hotspot on Sprint works well.0 -
I found that using ATT and iphone or iPad Hitspots works well Internationally I use a HUAWEI E5377 Hitspot and local country SIM's Results vary dramatically between carriers and geographic locations Example Works great on Orange France in Paris and Nice but blocks waterfall in Avignon. Worked great on Orange in Costa Brava Spain, Czech Republic and Freidrichshafen Will be testing it in Italy this week.0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
