why is it that most of the stateside (haven't tried DX ) telnet locations do not work in the N1MM pr
John Molenda
I was given the web address for K3WW to use on telnet by a Elmer on there yahoo lists . Has any one found another stateside DX spotter to work . If not why not am I doing something wrong? I finally got the program and my 6700 to work . John kb2huk
Hi John. I tried with VE7CC and K3WW and it worked fine here.
Are the spots visible on the bandmap? What's scrolling by on the "Telnet" window? Go to Window->Telnet and see if spots are scrolling by. If not, you might not even be connected.
Ria1 -
Hi John,
I had the same issue and added dx.k3lr.com:23 to the cluster list and it connected with no problem. I like the K3LR spots because they note the stations that use LoTW.
I worked the NAQP SSB contest last night using N1MM + for the first time with my 6300 and had no issues. K3LR spots showed up on the Band Map and was able to "slide or roll" up and down the band working one station after another with the Flex Control.
73, Gary
You may have a firewall blocking the traffic. In the case of K3WW, you need to make sure that you have TCP port 7300 open on your firewall(s).0
You could also ha e the filtering set funny Mike N9DFD0
I like the K3WW cluster because it's from our Club.
Go FRC!0 -
I get very few spots opposed to something like DX monitor . I know that the filter selections effect the spots but I have no filters running . ?0
Mine works va3mw.dxcluster.org port 41112
Mike va3mw
I had the same issue but it was because I did not have any "modes" checked Once I checked that parameter it worked fine
- 376 Community Topics
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 918 Genius Products
