why is it that most of the stateside (haven't tried DX ) telnet locations do not work in the N1MM pr
John Molenda
John Molenda Member
edited April 2020 in Third-Party Software
I was given the web address for K3WW to use on telnet by a Elmer on there yahoo lists .  Has any one found another stateside DX spotter to work .  If not why not am I doing something wrong? I finally got the program and my 6700 to work .  John kb2huk
  • Ria
    Ria Member ✭✭✭
    edited November 2019
    Hi John. I tried with VE7CC and K3WW and it worked fine here.
    Are the spots visible on the bandmap? What's scrolling by on the "Telnet" window? Go to Window->Telnet and see if spots are scrolling by. If not, you might not even be connected.
    Ria
  • Gary  w8vi
    Gary w8vi Member ✭✭
    Hi John,
    I had the same issue and added dx.k3lr.com:23 to the cluster list and it connected with no problem. I like the K3LR spots because they note the stations that use LoTW.
    I worked the NAQP SSB contest last night using N1MM + for the first time with my 6300 and had no issues. K3LR spots showed up on the Band Map and was able to "slide or roll" up and down the band working one station after another with the Flex Control.
    73, Gary
  • WG5D
    WG5D Member ✭✭
    edited October 2019
    You may have a firewall blocking the traffic. In the case of K3WW, you need to make sure that you have TCP port 7300 open on your firewall(s).
  • Mike NN9DD
    Mike NN9DD Member ✭✭
    edited August 2017
    You could also ha e the filtering set funny Mike N9DFD
  • Ria
    Ria Member ✭✭✭
    edited August 2017
    I like the K3WW cluster because it's from our Club. :)
    Go FRC!
  • John Molenda
    John Molenda Member
    edited September 2017
    I get very few spots opposed to something like DX monitor .  I know that the filter selections effect the spots but I have no filters running .  ?
  • Mike va3mw
    Mike va3mw Member ✭✭
    edited February 2018
    Mine works va3mw.dxcluster.org port 41112
    Mike va3mw
  • [Deleted User]
    edited April 2020
    I had the same issue but it was because I did not have any "modes" checked  Once I checked that parameter it worked fine
