Do I need a physical usb connection between my computer and flex 6700 to run N1mm spectrum scope
John Molenda
do I need a usb cable running from the radio to my computer when using n1mm software , spectrum scope with the new V.2 flex software ?
No, you use SmartSDR CAT installed on the PC running N1MM+
Thanks for the reply Dave. could you send me a picture of what my Sdr Cat should look like ? or maybe the config screen on N1MM . I had watched Al.s video on N1MM setup with Flex but his flex software version was prior to V.2.0 coining out ,so I think I also configured N1MM incorrectly . Thanks for your help John kb2huk0
John, you mentioned that you have already seen Al's video about Smartsdr CAT that was created using the older SDR version 1.8. I'm not aware of an updated video that demonstrates CAT for version 2.x (anyone else know something different?) But here is a link to the older video for reference to others reading this thread -- I think CAT works pretty much still the same ( again, anyone else can jump in here)
https://youtu.be/kMsC0waP2r0 0 -
The CAT set up is the same for 2.0; the port configuration has not changed.0
John,
As Tim mentioned I also didn't have to change the port settings for v2.
Also agree, the K0CN video mentioned by John/WA7UAR is great.
Here is a video I made with SmartSDR V2 that isn't in depth, but shows the setup options I'm using with V2 and the latest version of N1MM with the N1MM spectrum scope in vertical orientation (which is pretty neat.)
GL & 73, John AF3K
https://www.youtube.com/watch?v=4RrOHlTbi1I
Thank you so much for all your help guys this forum is the best ! John Molenda kb2huk1
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
