Mic input from Windows 10 to SmartLink
Terry K8EET
I thought this should be simple. I'm using a windows 10 laptop. The mic input talks just fine to the laptop but I can't get it into the Smartlink. I know I can't use DAX and I have to press the MOX button. I don't see any way to configure the mic input to the Flex software.
Did you select "PC" as the mic input in SmartSDR (In the TX control panel)? And the mic has to be the default recording device in Windows.1
Yes, I was just coming back to say I found it. I assume that was in the instructions. (I'm usually pretty good at reading the instructions) had to reset it to the default recording device which I had changed in the process after I had found the PC setting. Thanks Tim.0
:-)0
- 654 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 968 Maestro
- 940 Genius Products
