Mic input from Windows 10 to SmartLink
Terry K8EET
I thought this should be simple. I'm using a windows 10 laptop. The mic input talks just fine to the laptop but I can't get it into the Smartlink. I know I can't use DAX and I have to press the MOX button. I don't see any way to configure the mic input to the Flex software.
Did you select "PC" as the mic input in SmartSDR (In the TX control panel)? And the mic has to be the default recording device in Windows.1
Yes, I was just coming back to say I found it. I assume that was in the instructions. (I'm usually pretty good at reading the instructions) had to reset it to the default recording device which I had changed in the process after I had found the PC setting. Thanks Tim.0
:-)0
- 334 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 170 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 730 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
