How to re-dock panes?
ka7gzr
I really like the ability to un-dock panes. A nice feature. How do you re-dock the pane so that is attached to the main window?
Jim
ka7gzr
Press the little diagonal arrow in the top right.0
Thanks Ria. I did try that. Specifically it places the pane docked on the left side. If I hit it again (now an up arrow) it places it on the original right side undocked.
Jim
You can manually move the window by left clicking on the upper right gray area and drag the window wherever you want it.0
Thanks Jim,
My objective is to get it docked on the original right side like the previous versions. I could manually move it there but its still undocked.
Jim
ka7gzr
The standard tx control panel used to open up originally on the left side of the main window. Most users manually dragged it to the right hand side. Once moved, is would usually come back to the same right hand position if closed and reopened. Now with the pop-out windows, if you pop it out and back in, it will remember its popped out location the next time you pop it out. If, however, you close it from the task bar without popping it back in first, it seems to revert to the left-hand side when you open it again. At least that is the way I remember it happening to me a few times.... Ken -NM9P0
If you want it docked on the right hand inthe main window, make sure it is "in" and then drag it to the right hand position inside the main window. That should get it.0
Once popping out the control panel from the right side I can't re-dock it on the right. I can on the left side by selecting the down pointing arrow it moves it to the left side and attaches it to the main window. I can physical move the control panel to the right side it but can't attach it to the right side. It stays unattached. By "attaching" I mean its the same size of the main menu and clicking on the main menu doesn't move it to the background.0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
