PowerSDR 2.8 and WSJT-X 1.8 setup. Won't transmit
Hi Dave.
SDR1000 is no good. The recommended route for psdr is TS2000 emulation. However, as I discovered for other reasons, until a few days ago this didn't work either! I have been testing new TS2000 emulation software written by G4WJS and this solves the problem. The next release of wsjt-x hopefully will come out with this fix. You should find that omnirig will sort the problem in the short term. However TS2000 is the preferred route. As Darrin (KE9NS writer of the new psdr software) said to me a few days ago someone (not me because I can't do it) needs to write proper interface software for wsjt-x and psdr rather than rely on an old rig's software emulation. Any one offering here?
Having said that the updated TS2000 emulation works perfectly and should be available shortly.
73 Geoff G4XMJ.
Dave, I use the same setup with my Flex3k as the one I described in my tutorial:
https://community.flexradio.com/flexradio/topics/tutorial-setting-up-wsjt-x-with-smartsdr
I have created a virtual cat and a virtual ptt cable with VSPE and instead of HamRadioDeluxe
I use MiniDeluxe. The setup is the same as with SmartSDR, without it's CAT and DAX, of course.
Here is another tutorial:
http://kc.flex-radio.com/ExportPDF50362.aspx
73, Alex - DH2ID0 -
Thanks, Geoff! I tried TS2000 last evening, but so far, no luck. I'll check out the emulation software today. I'll keep at it. Darrin (KE9NS) is a great developer! He always replies to queries and REALLY understands PowerSDR!
Dave W5GT0 -
Thanks, Alex! I'll re-read your tutorials today and see if I can get this working. It receives just fine, but I'm getting several errors and it won't transmit.
Dave W5GT0 -
Success! I got it working by using HRD as an intermediary. I can now transmit. Haven't worked anyone yet (FT8), but it is transmitting and putting out about 10 watts. I selected HRD, which is connected to PowerSDR, as the "radio" and CAT. A bit cumbersome, but since I plan to use JTalert to log, it works out. 20 meters is really hopping with FT8. Thanks for the help Geoff and Alex!
Dave W5GT0 -
Just worked VE3SLM using FT8...success!!!0
Hi Dave.
The new updated TS2000 emulation version is not on general release yet, so I doubt you'll have any luck. Glad you got it working with HRD. Omnirig would also have worked. 73 Geoff. G4XMJ
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
