Hercules mp3 e2 controller
KB4HL
KB4HL Member ✭✭
Hello I have a Hercules mp3 e2 controller and am wondering if is able to be set up with the Flex 6300 and what is the setup, Any info would be greatly appreciated.
  • K5CG
    K5CG Member ✭✭
    edited October 2018
    N4PY has remote control software that you can map controls to functions and customize it. I figure I may as well mention it and beat him to it because I know he will mention it, multiple times.
  • KB4HL
    KB4HL Member ✭✭
    edited June 2020
    I have the n4 py software but figured I would check with other members to see how the use it. Thanks Danny
  • K5CG
    K5CG Member ✭✭
    edited August 2017
    I am not aware (I'm generally ignorant so...) that there is a 3rd party application for this particular controller. There are a couple of applications around you'll find for an integration to the Behringer CMD Micro DJ controller. I think the source is around too so you could start your own project.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited August 2017
    If you already have the Pegasus software, that may be your simplest choice.
    Otherwise, there are two or three threads from a couple years back dealing first with the Hercules DJ controller, then it morphed into the Behringer CMD Micro.
    Here is the original thread:
    https://community.flexradio.com/flexradio/topics/hercules-midi-with-6300
    The software was written using "Processing" and translated MIDI control values to commands sent to the 6000.  It is still a work in progress.  If you can handle some simple programming logic, the Processing language is fairly easy to learn and you can customize the program.
    I played with it a couple of years ago on the Hercules and then switched to the CMD PL1 controller, but never finished the project.
    Ken - NM9P
