Maestro-Wifi login problem
I **** my Maestro on internal battery. I did not switch Maestro quickly enough after warning "battery low" and Maestro switched off itself. Now when switched on, it requests entering PIN for my Wifi router. I enter a correct one, but Maestro does not connect, and enter PIN again, no connection again. FORGET button is greyed out, so I can not delete my usual network.
Is there a way to reset Maestro or rectify the problem? Is it a fault on Maestro side?
Sorry that I do not have the answer, but I'm quite surprised tha no one has answered you yet. I would like to know. Jeff0
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.
As I did not switch Maestro quickly enough after " low battery" warning appeared it most likely resulted in a glitch inside Maestro.
After trying to enter router PIN several times without a success , I connected CAT cable and run Maestro on external power supply for a while.
Next day I entered PIN and everything went well, problem solved.
Tom, SP7WT
- 115 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
