Maestro-Wifi login problem
I **** my Maestro on internal battery. I did not switch Maestro quickly enough after warning "battery low" and Maestro switched off itself. Now when switched on, it requests entering PIN for my Wifi router. I enter a correct one, but Maestro does not connect, and enter PIN again, no connection again. FORGET button is greyed out, so I can not delete my usual network.
Is there a way to reset Maestro or rectify the problem? Is it a fault on Maestro side?
Sorry that I do not have the answer, but I'm quite surprised tha no one has answered you yet. I would like to know. Jeff0
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.
As I did not switch Maestro quickly enough after " low battery" warning appeared it most likely resulted in a glitch inside Maestro.
After trying to enter router PIN several times without a success , I connected CAT cable and run Maestro on external power supply for a while.
Next day I entered PIN and everything went well, problem solved.
Tom, SP7WT
- 352 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 978 Third-Party Software
