Unable to register with Smartlin servers
Jim-KA4OJN
I am running a 6700 signature. Yesterday I was able to register and unregister with the smartlink servers. Today I am getting a message can't connect to servers. I powered down 12v. Powered it up and then did a master reset. Same thing. I am connected to the Internet. I also have not been able to connect the ports but that is because I am behind two routers. Only one of them is using DHCP. I will figure out that portion after I can again connect to the smartlink servers.
Jim KA4OJN
Jim KA4OJN
Make sure you are not connected to a VPN. That will confuse the Smartlink server.
Jim, K6QE
Hi, I do not have a VPN connected. Now I get the chooser screen where it says that the radio is available but when I try and connect I just get the circle going around.
Jim KA4OJN
I had that same problem with my iPad until I realized I was connected to a VPN. As soon as I got on the LAN, it immediately recognized me. Hope you get it solved.
Jim, k6QE
Hi,
After the master reset the IP address reset. I turned on DHCP behind this router to get an IP address than set a static address and now I am connecting with the radio again. I am on the LAN as I have not gotten smartlink going yet. Everything but SmartLink appears to be working. I have opened the ports in both routers but no luck. I can now register the radio with the SmartLink servers. So all that is left is finding out how to open the ports the way the radio wants them.
Jim KA4OJN
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
