Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
Integrating DX Cluster Spots with SmartSDR v2 (demo)
- 70 Community Topics
- 1.9K New Ideas
- 120 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 87 SmartSDR for Mac
- 144 SmartSDR for iOS
- 150 SmartSDR CAT
- 69 DAX
- 279 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 557 Maestro
- 14 FlexControl
- 723 FLEX Series (Legacy) Radios
- 153 Power Genius Products
- 119 Power Genius XL Amplifier
- 12 Power Genius Utility
- 22 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 89 Remote Operation (SmartLink)
- 50 Contesting
- 128 Peripherals & Station Integration
- 62 Amateur Radio Interests
- 405 Third-Party Software
Thanks for posting, it shows that integrating spots is clearly doable and they did a good job with the movable floor.
I don't use N1MM or contest and would like to see the spots integrated into SSDR. That way the panadapter is not duplicated or triplicated if you are also running CW Skimmer ( why waste screen space with 2 or 3 copies of the panadapter/waterfall)
The request to integrates Skimmer spots and/or DX spots is the number 5 request on the list by user votes.
If you are using N1MM you could display the spots in either place and turn it off in SSDR or N1MM as you prefer.
https://community.flexradio.com/flexradio/topics/pfskimer_what_is_the_possibility_for_a_smartsdr_dis...
The idea of the moveable floor for the DX spots is a good one and that comment should be added to the PFSkimmer idea.
It FRS decides to implement this idea it would result in a clean display with everything in one place and minimal use of screen space.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
SSDR / DAX / CAT/ 6700 - V 1.10.16
Win10
i.e: Spots on East Coast not heard by West Coast !
The Current GOLD STANDARD for Spots on the display in the Flex World is SmartSDR for iOS which integrates Spots into the Flex display where they belong not in yet another external panadapter... If you have ever used NAP3 (abandonware) on a K3 you will also see a totally integrated Spots on the Display
USE CASE: I chase DX even when travelling I do not have the time or inclination to scroll the bands to hear things.. I do look at the spectrum display and wonder what I am seeing. Putting up a Spots listing really does not do much good as you have 2 screens and have to mentally coordinate which is what.
I do not have screen area to have multiple extraneous displays for spot... Marcus got it right... with SSDR for iOS.. a single display where you can see everything
NOW it ONLY it could happen on SSDR...V2.1
BUT ONLY AFTER THEY FIX THE INVISIBLE METERS AND GIVE US AN ALTERNATIVE COLORS OPTION SUCH AS IN SSDR FOR IOS
Agree with having one seamless display and ideally we should be able to choose what we want to see there:
- DX spots and / or
- CW Skimmer spots
- or No spots at all
in one display, the SSDR display.
Alex (CW Skimmer author) is working on a new version slated for 2018. Ideally FRS will use his new server code and link it in seamlessly with SSDR.
So it could take a while but wouldn't that be a nice feature, something for everyone whether you favor CW, SSB, Digital, etc. I think all of these options are covered in the PF Skimmer idea.
Given the effort and timing there are definitely other easier and high ranking feature that would / should likely come first.
Regards, Al / NN4ZZ
Win10
By adding the CAT feature the log developers are free to implement enhanced spotting in the logger where IMHO is where is belongs.
Ria
The 6000 series has a finite amount of processing power. It would be nice to know if Spectral noise reduction can be added and if so, will there be much more room for other processes. Not likely we'll ever know that though.
Norm - W7CK
I am in agreement that spots on the display makes for an easier workflow and is a common use case for many hams casual, DX and contesters. However the implementation model is fraught with difficulty due to the need to consolidate three streams of data.
1) The applicable log
2) Spotting data - with all of the preferences and stuff associated with it.
3) Radio data mode, panadapter bandpass data etc.
As two of the three streams are already implemented in modern logging apps. I would look to the log authors to do the heavy lifting to implement a single consolidated view overtime. With FRS expanding as needed the interfaces needed to allow external apps to display content/attributes on a slice.
Today however, the added ability to pop out a slice works well for me as I can stack the slice above a horizontal spotting list and quickly see if a play exists for a given station.
a lot of hams want to operate from spots on the display rather than from a disconnected list or second art display
And if you are a CW Skimmer use it would be a THIRD display....why waste the space?
Regards, Al / NN4ZZ
Win10
I agree with you, Al; nice idea.
N1MM+ integration seems good for contesters but it is not for me (even though I use N1MM+ fed with telnet CW Skimmer). I wonder if CW Skimmer integration would be best for DXers. Either way, it would be nice to reduce the number of panadaptors covering the same frequency range.
Tried it this time using Maestro and it seems to work ok. i.e. whatever changes you make in the Maestro or Spectrum Monitor are reflected in the other. So it's also kind of a "poor man's multi-client" (but definitely not really because this is built for N1MM+ users only, and not the general case)
The release notes mention more to come, including being able to fine tune via the mouse wheel.
Pretty cool.
