SSDR 2.0 and Mac
George KF2T
Member ✭✭✭
Got home this evening and installed SSDR 2.0 without incident. Changed port forwarding on my Apple router, and SmartLink runs great at home or away on my iPad or iPhone. No observed problems with my Mac and DogParkSDR. xDAX for MacOS is broken under 2.0, but xCAT is just fine. So far, so good. The hardest part was breaking out the Windows laptop to do the update. The longest part was reading the directions. Thanks to the Flex team and alpha testers!
George
You had written some instructions for getting sound siphon working on a Mac some time back. I found the post but the document is no longer there. Since xDAX is broken, I need to setup my Sound Siphon again and I am having issues. Could you post that link again?
Burch0 -
I also noticed that with xCAT the voltage indicator is incorrect. Mine only shows 3.x volts. My DDUTIL also showed 3.x volts until I upgraded to the newest version of DDUTIL so something must have changed in SSDR 2.0 for this indicator.0
Upgrade DDUtil. I wrote a post the other day mentioning Users will need to upgrade it. Changes to the API cause older versions of DDUtil and also the xCat to read incorrect voltage. xCat will need to be updated to work with the API change. Dave wo2x0
I did upgrade DDUtil as I mentioned in the above post. It fixed the issue.0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
