License Required Message
Check the box for uPNP in the AT&T setup and then reboot your AT&T WiFi and radio. In SmartLink setup there is a down arrow to the left of where it says Network Settings to expand it. Make sure you are set for automatic and retest. You should get a green icon. The top section (uPNP) should say Pass.
Tried that again, Dave. Still a red icon.
UPnP Ports: TCP=FAIL UDP=FAIL
Same for forwarded ports.
I figured I'd have to do something else later for Smartlink, which really isn't a big deal for me. I'll try an Ethernet bridge as you mentioned earlier later.
I got the upgrade done, my main goal.
I do appreciate you and everyone else helping the less knowledgeable in all things IT (me) out with this stuff.
Tom N5MOA
This may well be what is happening with my installation. PC connected to radio via Ethernet cable and to route via Wi-Fi. Do I need to go and get a switch to connect the radio and the PC, or is there another way? If I get and use a switch and then run a cable (from the switch) across the house to the router, is that the only way I will be able to use the radio with SSDR 2.0?
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 948 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
