Maestro sofware version selection
Norm - W7CK
I've noticed that when I first turn on my Maestro, I see a list of the software versions installed. Is there a way to have the LATEST version automatically highlighted instead of always having to touch the screen and selecting it manually?
Is there a way to remove the older versions, at least from the display list?
Norm
Norm
The idea with retaining up to 5 older versions in Maestro is to be able to connect to different Flex radios that might have different software installed. I think this will make more sense when 2.0 comes out. I do like the option of defaulting to one if you want.
Any update on this? Is it possible to default to one version or remove old ones?0
Maestro will retain previous releases so you can revert back to an older release if desired. A user cannot delete them.
How many do you have showing? You should only have 3 right now.0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
