Loss of CAT in all applications after installing V2.0?
Craig McVeay
After installing V2.0 and getting SmartLink setup and running, I was feeling pretty good about this update. This morning, I sat down, fired it all up and when I opened WSJT-X, it will not communicate with the radio. Pop up says "Hamlib error: Communication timed out while opening connection to rig". I've checked and rechecked the CAT settings for the radio and in the application with no improvement. I tried Fldigi and I have the same issue going on. <EDIT> Please add Winlink Express with the same issue. The SmartSDR upgrade is the only change made since this all worked two days ago. Windows 10, WSJT-X v1.8.0-rc1 r7847; Fldigi 4.0.6.; Winlink Express 1.5.6.1.
Anyone else see and solve this riddle yet?
Craig,
Try this. Open SmartSDR CAT and add a TCP CAT port 5004.
Nest in WSJT-X Settings/Radio set ip up as per the following
Try that and see if it works better. Make sure you select Data/Pkt and also Fake It.
The IP is 127.0.0.1:5004
Did you cold boot the radio? Unplug 12v supply as described in the release notes? Fixed the problem for me.0
I have been using mine with no problem. But Im using Log4om as my log book and I am also using Omni-rig to control the radio on the FLdigi and WSJT. And when I log on those programs it puts in in my log automaticly then it goes to QRZ and then upload to Lotw. and there are others.
Good luck
Jay0 -
Thank you Dave. One down, a few more to go. Gotta take off for work now though. I assume a similar change in other applications will have the same effect?
Craig
N0CSM
Did you remove the "in use" ports after upgrading to SmartSDR v2.0.17 as instructed to do in the Release Notes? If not, that can cause problems creating ports.0
Thanks Dave
73's Dan
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
