First pass beginners guide to WSJT and FlexRadio
Hello all,
A flex user asked for some help on setting his Flex 6700 setup to work FT-8. I decided to put together a simple beginners guide based around Windows.
I'm sure I have some bug and inaccuracies and I will gratefully accept comments and corrections. This process however does work for me.
I am hopeful it will help someone else.
https://dl.dropboxusercontent.com/u/7578983/BeginnersGuide-WSJT-FlexRadio.pdf
Thank You Mark. On a quick skim it looks like what I've been looking for. Keep up the good work! -Dave
Mark,
Thanks for the guide. Do you think WSJT will work via SmartLink? The concern would be the latency involved. I believe the absolute timing accuracy for WSJT is pretty tight.0 -
Mike, it will not at this time because DAX does not work over Smartlink. Perhaps when that is solved and depending up on the latency it might.0
Mark, I note your comment on using a COM Port for the CAT control of WSJTX. In my WSJTX setup I have selected "FlexRadio 6xxx" as the hardware, and then for the network server I use "127.0.0.1:5002". In SmartCAT you can also define different TCP Ports if you already use 5002 - for example DDUtil. Otherwise all my other settings are the same as yours. 73 Peter G3ZSS
Agreed. I couldn't get to to work when I first tried that but now it is. I've updated the doc. Thanks!0
Updated the doc to include the TCP cat connection and fixed a few misspellings!0
The File is no longer available. I used the IP address of my radio, I added a CAT port of 5003 and cannot get connected. I have SmartSDR running don't I have to have that running too?
Peter0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
