Does DAX v2.0.17 work with Smart Link?
Javier, KC2QII
While testing Smartlink from my office fro the first time, DAX v2.0.17 does not extend audio to my external digital application. Direct connection via VPN works as expected. To eliminate the possibility of firewalls at the office end, I switched to a router the network firewall, with the same results.
Any ideas?
Javier
Any ideas?
Javier
DAX currently does not work via SmartLink. You can only have DAX running on the same local network.0
. I was to post a "never mind" after finding at the the answer at bottom of the V2.0 FAQ file.
Thanks for the quick response.
Javier0 -
I am in the same situation. DAX is not connected at my remote site. I am connected with SmartSDR and I can operate the radio controls. My next issue to resolve is audio from SSRD to my headphones. I have looked at lots of menu items , just have not seen how to direct the audio. The radio for slice 1 shows DAX as the audio out.0
As noted above, DAX is not supported over SmartLink. We are evaluating adding it in a future release.3
Ron,
If you are using SmartSDR on a laptop, just press the REMOTE button on the top right corner of the screen. This will send the audio to the laptop's default audio device that is running SmartSDR.
I have run remote many times from Hawaii and I have not had issues with audio or DAX but that was running over a VPN connection.
**** me! Selected Remote as you said and I am working correctly. Thx to all.0
Ok no DAX on SmartLINK, but I hope in future can make digimode directly from Maestro, I mean not difficult to implement a Digital Mode engine (PSK, RTTY)0
We are considering using DAX on Windows for SmartLink. We have no plans to add DAX and the ability to run digital modes on the Maestro.2
I'd love to see DAX get SmartLink support in a future release. So here's a +1 vote...
Great job on v2!0 -
duh..., i should have thought about that THANKS! works now
Yes please add SmartLink support for DAX. It would be a big step forward.0
To Ron: I did the same thing with the remote button. I knew one had to press it on LAN remote because you are likely to be local, but I figured when on WAN remote, Smartlink would know I was remote and wouldn't have to press the button. --Mike, WV2ZOW0
I've already said my piece but I vote for DAX (at least for audio, I/Q is optional) on SmartLink.
Definite +1 here. The ability to run digital modes remotely would be fantastic0
I vote for DAX on SmartLink.
I did not know that you could not work digital modes from the Maestro remotely. Just bought a 6300 and Maestro that will be delivered tomorrow, well hope they do an upgrade where that will happen, soon lol.
- 329 Community Topics
- 597 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 397 SmartSDR for Mac
- 260 SmartSDR for iOS
- 247 SmartSDR CAT
- 180 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 163 FLEX-8000 Signature Series
- 911 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 726 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 945 Third-Party Software
