SmartSDR Version 2 License did not register if SSDR network address was set to Static
Ali 9K2WA
SmartSDR Version 2 could not register the license if the radio IP was set to Static in the network settings before upgrading to SmartSDR Version 2.
The problem was solved when I downgraded back to SmartSDR v1.10.16 and change the network setting to DHCP and upgrade again to SmartSDR Version 2.
On your static address, was there a Gateway specified? That would prevent it from updating.
Yes there was a Gateway specified.
Later on I will revert back to a static IP, one of the problems I ran across also was not enabling uPnP in my router which prevented SSDR for IOS to connect.
I guess I was to anxious to install Version 2, I did not read everything!0 -
Excellent. Glad you figured it out.0
fwiw, I had a static address configured and didn't have any issues registering the license.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
