HELP Connecting a Flex 3000 to a Expert 1k-fa
M0AOV
Hi All
I'm trying to connect my Expert 1k-fa to my Flex 3000, I've looked on the Flex forum but only really see information on the connection using the Flex 6??? radio's, so has anyone done the connection to a Flex 3000 and how did you do it?? cable connection and Radio to Amp connection ??
Thanks in advance
Rob
Thanks in advance
Rob
Hello Rob,
Download and install DDUtil
More details on http://k5fr.com/DDUtilV3wiki/index.php?title=Download
Tom, SP7WT
Thanks Tom will get that done, is there any other information on what cables or leads I'll need to make up for the connection from the Flex 3000 to the Expert 1k and PC ??? I have no idea so far
Rob
If you don't find the info you need you can have the cables made for you here.
Thanks Larry will have a look0
You need to make a CAT cable, it is quite simple, Expert 1k manual provides details.
Also, a quality USB to RS232 converter with with original FTDI chip is required. Some fake chips may not work properly.
Tom, SP7WT
You can buy the cable from Dan at Expert linears, or you can make your own:
9 pin serial (PC running DDUtil --------> 15 pin (amp
Pin 2 (RXD) ------------------> Pin 9 (TXD)
Pin 3 (TXD) ------------------> Pin 1 (RXD)
Pin 5 (Ground) ------------------> Pin 4 (Ground)
Connect the cable to a PC and set it up in DDUtil. For the 3000 you have to use DDUtil.
Ria1 -
Thanks for all the replies just need to make sure about the serial 9 pin from the PC to the Expert 1K which would be the 15pin connection either Cat 1 or Cat 2 connection and from the Flex 3000 use which one ?? PPT Jack or the External Keying Line ??? to the Red Relay RCA on the Expert 1K, I've seen other posts saying use the RS232 9 pin connection on the Back of the Expert 1K on the right side so I just want to make sure of the connections.
Thanks0 -
Use CAT1. CAT2 is if you have a 2nd radio0
Thanks Ria what about ( PPT Jack or the External Keying Line ??? to the Red Relay RCA on the Expert 1K, )
Thanks0 -
I find that wired PTT works very well and this is what I use.
Thanks for the replies All but if your going to reply then PLEASE explain what you are talking about, YOU might know what your talking about but some one who has never done it HAS NO IDEA so please Explain,
TOM what do you mean by WIRED PTT ???0 -
What I'm trying to find out is:
1) TO KEY THE EXPERT 1K, DO YOU USE the PTT Jack or the External Keying Line ??? Both are RCA CONNECTIONS, The other end of the lead from the Flex 3000 goes to the red relay RCA on the back of the expert 1k ?? if you are using CAT 1 for the Flex 3000
2) Is there a Video on Youtube or any where else that anyone knows of showing you how to set the setting up in DDUtil for the Flex 3000 to a Expert 1K ??
Thanks again for all the replies it's the little things that are the hardest to sort out.
Rob0 -
Hello again, Rob
Wired PTT- connects Flex PTT RCA socket with Expert's PTT socket using a length of screened cable with RCA plug on each end. A simple and effective solution.
DDUtil creates ports to exchange data between Expert and Flex radio.
Please prepare your RS232 to USB adapter, and a cable according to Ria's suggestion then continue with DDUtil installation. Note COM port number assigned to the adapter.
If I remember correctly, you meed to select a Legacy Radio from the setup and continue with further settings.
DDUtil website has a small help file.
Meantime I will find more how to continue with the setup.
Also study Expert's manual. You will need to setup menu in the amplifier related to CAT settings.
Tom
2
- 379 Community Topics
- 634 The Flea Market
- 135 SmartSDR+
- 198 DAX
- 43 Aurora
- 956 Maestro
- 301 Shack Infrastructure
