VAC audio subsystem error -9988 in PSDR
N8FNR
When I click on Direct I/Q Output to VAC I get an Audio Subsustem invalid device, -9988 port audio error, invalid stream pointer error. Any thoughts on how to get rid of that? Trying to get CW Skimmer working. Running KE9NS PSDR v2.8.0.40 and VAC 4.12.0.4974.
Zack N8FNR
Here are my settings in PSDR:
Driver Win WDM-KS
Input VC cable 1
Output VC cable 2
Buffer 2048
Sample rate 9600
VAC Settings
SR 11025 - 96000
BPS 8 ..32 NC 1..2
Connected source Line
Max inst 20 Msper int 7
Stream fmt limit cable range
Stream buffer low 50 high 200 max wait 300 ms
Enable channel mixing yes
Zack N8FNR
Driver Win WDM-KS
Input VC cable 1
Output VC cable 2
Buffer 2048
Sample rate 9600
VAC Settings
SR 11025 - 96000
BPS 8 ..32 NC 1..2
Weirdly if I uncheck Calibrate IQ I can check Output to VAC and CW Skimmer will start to decode.0
Was able finally fix this. I loaded the newer version of PSDR from KE9NS then created a new PSDR DB. When that did not work I finally looked at the manual and made the buffer size and sampling rate of PSDR the same as the Flexradio firewire app. All issues solved and everything is working as expected.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
