Audio Routing
joe camilli
For many years I have been using a M-Audio Delta 1010LT to route all my audio sources(Flex 5000, Scanner, 2/440 radio, 900 radio and computer) to one set of speakers. This has worked very well. Recently I added Bluetooth and a Bluetooth headset to this computer to get rid of the wired headset. However when the Bluetooth headset is connected the only audio i hear is the computer's.
Any suggestions how I get the audio from the other devices to route to the Bluetooth head set?
Joe N7QPP
Joe N7QPP
You could try connecting a Bluetooth transmitter to where you had your wired headset connected and pair with your Bluetooth headset.
I know the flex is controlled by a computer, but I think you are over thinking it when it comes to the audio. To me, I rather control my audio with a mixer with faders, eq, etc. Give me a good clean audio in and out into the mixer and then let the mixer do the rest for distribution of sources. I don't like the sound of audio through Bluetooth. To me tone qualities and dynamic range go to ****. But then again, I hear like a cat....especially the highs.....it's wierd because I'm starting to lose base sound but I still can hear way up.....that's not normal at all. I haven't found one Bluetooth Headset yet that I'm happy with yet. Now, wired headsets.....I love tons of them. David, aa6rv
Bluetooth devices need to be 'paired', I suspect your headset is paired with computer, not your mixer board. Try turning off computer Bluetooth and 'pairing' headset with Bluetooth transmitter on mixer output.0
If your Bluetooth device is paired and working, press "remote" near the top right portion of the SSDR screen. Works a trick for me and my BT headset.0
some points of clarification. The mixer is a software one as part of the 1010lt driver. And I am using PSDR for the Flex 5000. Sorry for the cross post
Joe N7QPP
Joe,
You may be able to use the window sound system 'Listen' function to route audio from the m-audio device to a windows playback device ( default - bluetooth ? )..
Multiple windws recording devices ( inputs ) could be routed to the same playback device..
Just a suggestion.
AL, K0VM
Thanks AL,
Works great...
Joe N7QPP
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
