Suddenly no audio or shown received signals but TX fine with SDR 1.10
Kari Gustafsson SM0HRP
Hi, This has happened now two times after updating to 1.10.8. From cold start when I turn on the Maestro (or SDR on PC) I cannot see any signals on the panadapter or hear anything of the 6700. But sending works fine in tune mode (10 W) and full 100 W output. First time it happened I tried to look for possible causes and then suddenly it came into normal receiving mode while pressing tune on Maestro. Like tune triggered something. Now the 2nd time I cannot find any ways (not even pressing several times on tune) to get it into normal receiving mode. It applies to at least one or two slices that I have used. All are "dead" with respect to receiving or producing any audio at all. Sending OK on both slices with different antennas on ANT1 and ANT2 respectively.
Any clues?
Any clues?
Audio, panadapter and metering data is provided by a VITA-49 UDP data stream between the client and the radio. The "command and control" of the radio is done via a different stream that uses TCP. Usually when the client can control the radio, but no audio or panadapter data is being seen we usually suspect a network security suite or firewall on the network (router or on the PC) that is blocking it.
If the issue is intermittent, then we suspect a network throughput issue, as the VITA-49 UDP data stream is responsible for a vast majority of the traffic between the radio and the client.
Lastly, the issue could be the radio, but the proper troubleshooting technique is to rule out a firewall and/or network issues first.0 -
Hi Tim,
Thanks for the reply. This did never occur before updating to 1.10.8. Any changes in the software with 1.10.8 in this respect that may have introduced this behavior?
73 Kari SM0HRP0 -
Based on the behavior you reported, I cannot think of anything off the top of my head that was done in 1.10.8 that might be responsible that behavior.0
Windows update?0
That might be a remote possibility. Usually Windows Update only messes with CAT and DAX.0
Thanks for inputs. Not beeing a computer geek what remedies are there to check correctly UDP streams? Wire shark and appropriate ports? Any clues? BTW checked but no Windows updates made in PC...73 Kari0
I'd open a HelpDesk support ticket for advanced troubleshooting.0
Hello again , Now exactly same thing has occurred. That is "dead" slices but TX OK. I use latest release 1.10.16.
73 Kari0
- 656 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 940 Genius Products
