Changing width of transmitted signal on Maestro
Tony C kc2dis
This question may seem a little silly. I will try to make myself clear. During the last contest, I noticed that I could not find a way to change the width of the TX signal of the active slice on the Maestro. Sure, it is easy to adjust the width of the slice receiver, but if i want to change the equivalent of the TX high and low cut, similar to the way you can with the functions in SSDR for the PC, how does one accomplish this? Is it even possible? Thanks in advance.
It is in the microphone settings window of the Maestro.0
Yes, it's in the manual page 145. http://www.flexradio.com/downloads/maestro-user-guide-pdf/
Mack
W4AX
Alpha Team0 -
read the manual.0
Recommending to check the manual first as a best practice is a little more congenial.
Let's all try to be good elmers.4 -
Thanks Tim and to all the kind help. Flex community is great0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
